[Ky...] Posted April 13, 2020 Share Posted April 13, 2020 Hey All, We are proving a new process on a new machine. The Datum A cylinder in one end is 1.573 +.000/-.001 X 8.00" long. I have 5 circles to check of taper and everything. Is there a way to just create a cylinder with 5 circles and pull the diameter of each circle? or do I have to just have 5 circles on the cylinder and recall points into a cylinder. Just trying to try something new. Thanks Kyle Link to comment https://qualityforum.zeiss.com/topic/16036-can-you-pull-dimensions-out-of-a-cylinder/ Share on other sites More sharing options...
[Mi...] Posted April 13, 2020 Share Posted April 13, 2020 Open a new Circle from the Features Menu Recall Feature Points and right click the Cylinder. In the menu select Open. You should get a listing of all the Circle Paths for that Cylinder. Select the Path that you are interested in. Lather Rinse Repeat Link to comment https://qualityforum.zeiss.com/topic/16036-can-you-pull-dimensions-out-of-a-cylinder/#findComment-88664 Share on other sites More sharing options...
[Ow...] Posted April 13, 2020 Share Posted April 13, 2020 I submitted a request several years ago to make the size of each diameter measured reported on the cylindricity plot like location is now for each but, I don't believe I heard anything from it. Link to comment https://qualityforum.zeiss.com/topic/16036-can-you-pull-dimensions-out-of-a-cylinder/#findComment-88666 Share on other sites More sharing options...
[Ky...] Posted April 13, 2020 Author Share Posted April 13, 2020 Owen, That would be nice to have. Wish Zeiss would listen to you. Michael, That worked just like I was wanting. Thank you Link to comment https://qualityforum.zeiss.com/topic/16036-can-you-pull-dimensions-out-of-a-cylinder/#findComment-88668 Share on other sites More sharing options...
