[Pi...] Posted December 1, 2022 Share Posted December 1, 2022 Hello, is it possible to export a .ginspect file to solid .step not surface with gom inspect software. If it's not possible have you a good tips, a free software ..... I work on Inventor by autodesk. Thank you for your help Link to comment https://qualityforum.zeiss.com/topic/1606-how-to-export-a-ginspect-file-to-solid-step/ Share on other sites More sharing options...
[Be...] Posted December 5, 2022 Share Posted December 5, 2022 Hi, .step is usually a CAD format and therefore you must convert the measured triangle meshes to parametrical surface descriptions (e.g. B-Rep or Nurbs-Patches). This is usually done with a reverse engineering software, e.g ZRE or Polyworks. I'm quite not sure but I guess that all of these software packages have only commercial versions. Regards, Bernd Link to comment https://qualityforum.zeiss.com/topic/1606-how-to-export-a-ginspect-file-to-solid-step/#findComment-5379 Share on other sites More sharing options...
[Pi...] Posted December 7, 2022 Author Share Posted December 7, 2022 Thank's Bernd Link to comment https://qualityforum.zeiss.com/topic/1606-how-to-export-a-ginspect-file-to-solid-step/#findComment-5435 Share on other sites More sharing options...
[Jö...] Posted December 14, 2022 Share Posted December 14, 2022 Hi there, Autodesk Fusion 360 has a feature to calculate a STEP from a STL file. It works "okay" but you should not expect a real usable STEP, with things like cylinders or anything like this. Also there is a "free" Version for Makers... There is also a plugin available for Inventor called "Mesh to Solid" that can convert an STL. Really suitable but only for very low polygon objects with at the same time high requirements for RAM and CPU. Regards Jörg Link to comment https://qualityforum.zeiss.com/topic/1606-how-to-export-a-ginspect-file-to-solid-step/#findComment-5489 Share on other sites More sharing options...
[Br...] Posted April 19, 2023 Share Posted April 19, 2023 Is anyone aware of a step-by-step instruction for turning mesh to STEP or IGES in ZRE? I am trying to get there with the very sparse walk-through provided with the software, but am having no luck with desired end result. Link to comment https://qualityforum.zeiss.com/topic/1606-how-to-export-a-ginspect-file-to-solid-step/#findComment-7577 Share on other sites More sharing options...
