Question regarding the rotational speed control.
Hello, I previously worked with a 2017 Contura, and now work with a 2006 Contura G2 model. We recently updated the remote module to what the 2017 Contura has. When running the 2017 Contura, I was able to control the speed in which the stylus would rotate between features, which was beneficial during program prove outs. When I received the identical updated remote module for the 2006 Contura G2, the speed control does not allow any speed variation when the stylus is rotating, only rotates at one speed uncontrollable. Is there a way to change this, and be able to control the speed when rotating the stylus? Thank you in advance.
  • 3 months later...
I believe that this is either a FW on the c99 function or a function built into the new style RDS found on newer machines. Sorry 🙁
