[Bi...] Posted March 31, 2020 Share Posted March 31, 2020 Hello, I've written an inspection routine on a Zeiss O-Inspect utilizing both tactile (probe) and optics (camera). The routine operates as expected HOWEVER, if I re-qualify the probe, the optics do NOT hit the same locations as PRIOR to when the probe was re-qualified. Does anyone have an explanation and/or a solution? Thank you Link to comment Share on other sites More sharing options...
[No...] Posted April 8, 2020 Share Posted April 8, 2020 You probably need to execute the tacile-optical adjustment measurement plan. Link to comment Share on other sites More sharing options...
[Ma...] Posted April 8, 2020 Share Posted April 8, 2020 Please sign in to view this quote. Exactly this. When you qualify the tactical stylus the relationship between the tactical stylus and optics are broken. The tactical to optical program updates relationship between the two. Link to comment Share on other sites More sharing options...
[Ch...] Posted July 2, 2025 Share Posted July 2, 2025 What happens when the tactile_optical_adjustment_and_check program doesn't work? There's an issue with our focus. I tried creating a new camera optics configuration but it still won't run... There's an offset between the probe and the camera, but I cannot correct it with the defined program. Thoughts? Link to comment Share on other sites More sharing options...
