[Br...] Posted April 7, 2020 Share Posted April 7, 2020 Hi All, We are taking 18 points on a cylinder. The locations of the points are customer specified and they want the distance from the point taken to nominal on the inspection report ( space point ). Is there a way to display the space points of a cylinder? We tried taking 18 individual points, getting the space point measurements from each point, then recalling them into a cylinder but we are getting wild numbers on the space points. Any advice? Thanks in advance! Link to comment Share on other sites More sharing options...
[Ri...] Posted April 7, 2020 Share Posted April 7, 2020 Did you do Recall or Recall Feature Points? Recall Feature Points would carry over the vector information. Link to comment Share on other sites More sharing options...
[2b...] Posted April 7, 2020 Share Posted April 7, 2020 You can create a point manually, Features > Point, Change the evaluation to Space Point, and then go to Recall Feature Points, find the cylinder, right click on the Cylinder from the list, and select Add Range Limits Then from the first button choose the point number you're interested in. Use that in a Space Point distance characteristic. Link to comment Share on other sites More sharing options...
[Br...] Posted April 7, 2020 Author Share Posted April 7, 2020 Thank you Laura, worked perfect! Link to comment Share on other sites More sharing options...
