ASME vs ISO Profile
As far as I can tell, there is no difference in the evaluation itself. It is still the maximum distance between the extracted profile and the nominal profile.
I've never seen what you've shown, and I don't know why you'd ever do that. It makes no sense. All of the examples for ISO & ASME show the profile tolerances to be exactly shaped like the nominal profile.
The only differences arise from describing what type of profile it is (unilateral, and to what side).
Regarding the DRF - I was referring to how Datums are built in ASME vs ISO. I'll attach a long snippet of an email that I sent out a couple of years ago.
https://qualityforum.zeiss.com/topic/16110-asme-vs-iso-profile/#findComment-89212
The plot thickens.... My original question was asked by our customer but I didn't know the underlying reason. It turns out that their vendor is using PC-DMIS and the question of how standard bi-lateral profile is calculated. So, Calypso is using max deviation times 2 and PC-DMIS is adding Max and Min deviation, if I understand correctly though I've heard it a hundred times. Open the flood gates....
https://qualityforum.zeiss.com/topic/16110-asme-vs-iso-profile/#findComment-89216
