[Di...] Posted March 18, 2020 Share Posted March 18, 2020 03-1 ven К2 Z=3.5.pdfExplain, please: where is mistake in my programme gear. I have such result profile only gear with a=30°. Link to comment https://qualityforum.zeiss.com/topic/16158-profile-on-gear-a30%C2%B0/ Share on other sites More sharing options...
[Ro...] Posted March 18, 2020 Share Posted March 18, 2020 Please activate the tooth thickness deviation. I bet you´ll see a big difference from actual to nominal tooth thickness. If this is the case the second flank (typically the left one) which is not used for feeding in shows this "shifted" profile deviation curves. The reason in this cases is the tooth thickness deviation Link to comment https://qualityforum.zeiss.com/topic/16158-profile-on-gear-a30%C2%B0/#findComment-89568 Share on other sites More sharing options...
[Di...] Posted March 20, 2020 Author Share Posted March 20, 2020 Where do I can to activate the tooth thickness deviation? Link to comment https://qualityforum.zeiss.com/topic/16158-profile-on-gear-a30%C2%B0/#findComment-89570 Share on other sites More sharing options...
[Ro...] Posted March 20, 2020 Share Posted March 20, 2020 Link to comment https://qualityforum.zeiss.com/topic/16158-profile-on-gear-a30%C2%B0/#findComment-89572 Share on other sites More sharing options...
[Di...] Posted March 20, 2020 Author Share Posted March 20, 2020 It's ativate. It's doesn't help 🙁 Link to comment https://qualityforum.zeiss.com/topic/16158-profile-on-gear-a30%C2%B0/#findComment-89574 Share on other sites More sharing options...
[Ro...] Posted March 20, 2020 Share Posted March 20, 2020 If it does not appear please send the .act file to the ZEISS support team for analysis. Link to comment https://qualityforum.zeiss.com/topic/16158-profile-on-gear-a30%C2%B0/#findComment-89576 Share on other sites More sharing options...
[Di...] Posted March 20, 2020 Author Share Posted March 20, 2020 Thanks.) Link to comment https://qualityforum.zeiss.com/topic/16158-profile-on-gear-a30%C2%B0/#findComment-89578 Share on other sites More sharing options...
[Di...] Posted March 29, 2020 Author Share Posted March 29, 2020 Roman Gross thank you very much for you advice. You were right, that there's a big difference between actual and nominal tooth thickness. But my engineer of technologist cannot understand: why 😮 😮 ? I thought that picture of profile will change in act.file , but nothing. May be I will measure a new gear with "correct " tooth thickness and see a good picture profile . Sorry for my bad English 😉 Link to comment https://qualityforum.zeiss.com/topic/16158-profile-on-gear-a30%C2%B0/#findComment-89580 Share on other sites More sharing options...
