[Ri...] Posted March 11, 2020 Share Posted March 11, 2020 How do you get the "default report" to quit popping up when you are selecting features? Link to comment Share on other sites More sharing options...
[Mi...] Posted March 11, 2020 Share Posted March 11, 2020 Go TO MULTIPLE REPORT WINDOW>>>Use drop down under the REPORT FEATURESand choose the DEFAULT report from the list. Now with the default highlighted, Click on the GREEN check mark that is on top of the monitor icon under the media output section. This will make a red X in the box that once had a green check. Then save your prg and the it will stop popping up. BUTTT it is not global. You have to change each program for the window to totally stop Sucks I know.... Zeiss will one day fix this Link to comment Share on other sites More sharing options...
[Ri...] Posted March 11, 2020 Author Share Posted March 11, 2020 thanks, I was hoping for it to be a setting that was active globally.....I suppose the annoying pop up in the middle of the screen will be reminder enough 🙄 Thanks! Link to comment Share on other sites More sharing options...
[Sa...] Posted March 27, 2020 Share Posted March 27, 2020 I just minimize it and that seems to work just as good Link to comment Share on other sites More sharing options...
