manual input_key in feature??
Does anyone know if calypso offers anything like a key in feature(PC Dmis) ?????
I like to add some manual checks in my programs sometime and it will prompt you like an optional stop in the program. You can add nominal and stated tolerances and a name ie cal, gagepin, micrometer etc.....it also puts them on the CMM report.
Along with using the feature or characteristic settings editor to make it CNCvsMan, the result element may be able to do what you're wanting??
Several ways it could be done but, you might need PCM to do it.
I don't have PCM anymore so I can't test it but, using Parameter Coded Measurement with para files would do it.
Do you have PCM?
If this can be done without purchasing an additional licence (PCM) in PC Dmis, then that's in their sales favor.
