End of run position???
Is there another setting that you can set a position at the end of a program that would override the CNC End Park Position?
I received a program from one of our other plants and have set a CNC End Park Position, but at the end of the run it goes to a different position.
It will go to the position I set if I "Execute" running a feature.
I've been digging and can't seem to figure this out. Can anyone set me in the right direction?
Marc
https://qualityforum.zeiss.com/topic/16186-end-of-run-position/
So, it looks like I am stuck with this.
It is not that big of deal since it's in a position where there is no risk of crashing into anything. It is more of an annoyance as the operators running parts will have to manually move the head after the run to remove their parts.
Would be nice if the software will allow you to either remove the position or at least warn you that there is PCM code and a risk of collision.
I can have our other plant send me a copy with this removed.
Thanks for your help guys!
https://qualityforum.zeiss.com/topic/16186-end-of-run-position/#findComment-89816
I found positionCMM in the inspset file, tried adding the forward slashes and it is still driving to that position. I thought maybe I was adding it in the wrong place and tried multiple variations.
I actually tried removing the position from that line and still no change.
There has got be something else happening.
Its weird that the location it drives to is the front right corner of the CMM. It just seems like an odd location kinda in the way rather than out of the way.
Thanks for your help trying to figure this out though.
https://qualityforum.zeiss.com/topic/16186-end-of-run-position/#findComment-89828
Nope 🧑‍💻
Try this:
#parameters: '//positionCMM(350,-350,-200)'
Keep in mind: The code you see in the inspset file is like a "shell" for the actual PCM code. The PCM code is the part between the single quotes. So you have to put the slashes inside the quotes.
https://qualityforum.zeiss.com/topic/16186-end-of-run-position/#findComment-89838
