[To...] Posted March 16, 2020 Share Posted March 16, 2020 I have this part were I am currently doing a formula to give me the tolerance, but I guess there should be someway to avoid this. How can I construct this and let Calypso do the calculation for tolerance? I have tried different things, but I guess I haven' tried the right one yet. Link to comment Share on other sites More sharing options...
[Te...] Posted March 16, 2020 Share Posted March 16, 2020 You can create a theoretical circle using formula to fill in the info you want (X,Y,Z, DIA) and then report position to that circle which will allow for MMC Link to comment Share on other sites More sharing options...
[Ch...] Posted March 16, 2020 Share Posted March 16, 2020 Or possibly theoretical planes at this intersection point, the symmetry plane should allow for MMC. Theoretical circle should work just as well, make sure ID/OD is specified correctly for MMC. Good luck and happy measuring. Link to comment Share on other sites More sharing options...
[To...] Posted March 17, 2020 Author Share Posted March 17, 2020 Please sign in to view this quote. This could maybe be an option, but the two slots has to be evaluated as CT, so it should actually be a cylinder combining the two slots. Link to comment Share on other sites More sharing options...
[To...] Posted March 17, 2020 Author Share Posted March 17, 2020 Please sign in to view this quote. I am not sure how to do this. Any ideas? What I am doing now is; Scanning two lines in the depths of 0,8. Link to comment Share on other sites More sharing options...
[Ch...] Posted March 17, 2020 Share Posted March 17, 2020 What are the features in the slot, it appears to be planes/surfaces at 80°, if these continue past the 0,8 basic here's what I might recommend: measure each 80° plane. Create /construct a 0.8 theoretical or offset plane from the surface shown. Intersect this with each of the (2) 80° planes. This should give you an "x" value position or whatever axis these features lie in. Construct a theoretical plane using these "x" values. Construct symmetry plane from these 2 planes. Calypso should allow for MMC. Watch the direction of the planes, make sure they correspond with MMC, not LMC. There are other ways to do this. Create a theo circle based on x1+x2 dist value. Possibly fitting circle in contour as well, which might be the most challenging. Good luck. happy measuring! and happy st pattys day ! 🤠 Link to comment Share on other sites More sharing options...
[An...] Posted March 19, 2020 Share Posted March 19, 2020 See attached. Contribution_19_03_2020_1.pdfFetching info... Link to comment Share on other sites More sharing options...
