[Ry...] Posted March 11, 2020 Share Posted March 11, 2020 How do you create an alignment with offset dowels? Link to comment Share on other sites More sharing options...
[Cl...] Posted March 11, 2020 Share Posted March 11, 2020 Yes you can. What type of alignment do you need? Can you be more specific? Link to comment Share on other sites More sharing options...
[Ry...] Posted March 11, 2020 Author Share Posted March 11, 2020 I have a dowel that I is zeroed and the other dowel is X of 5.500" and Y of -3.000". These are the locator dowel for a fixture. Link to comment Share on other sites More sharing options...
[Cl...] Posted March 11, 2020 Share Posted March 11, 2020 Although I have not used this option in a long while. I believe you go to the "Special" tab in the Base Alignment window, choose rotate by distance's. Then you enter your XY offsets. You first make one dowel XY zero and then planar rotate the second dowel, then the rotate by distances, make sense? Link to comment Share on other sites More sharing options...
[Ry...] Posted March 11, 2020 Author Share Posted March 11, 2020 Thank you Clarke!!! This seemed to work. Link to comment Share on other sites More sharing options...
[Ow...] Posted March 11, 2020 Share Posted March 11, 2020 Not sure who created it but, attached is nice document defining how to do it. Link to comment Share on other sites More sharing options...
[Me...] Posted March 11, 2020 Share Posted March 11, 2020 Anyone know how to do this same thing on PC DMIS? Link to comment Share on other sites More sharing options...
[Ri...] Posted March 11, 2020 Share Posted March 11, 2020 Please sign in to view this quote. .... Link to comment Share on other sites More sharing options...
[Ad...] Posted March 11, 2020 Share Posted March 11, 2020 Please sign in to view this quote. Unless it's changed I always needed to align to the second diameter and rotate by the calculated angle in PCDmis and OpenDmis Link to comment Share on other sites More sharing options...
[Ri...] Posted March 11, 2020 Share Posted March 11, 2020 Please sign in to view this quote. I don't know about PC-DMIS, but in my experience with DMIS, you could offset the feature, and then align to it. Or yes, work out the Trig. Link to comment Share on other sites More sharing options...
[Me...] Posted March 11, 2020 Share Posted March 11, 2020 Please sign in to view this quote. A former coworker & did this method...Not a huge fan but not many other options.. Whatayagonnado ¯\_(ツ)_/¯ Link to comment Share on other sites More sharing options...
[Cl...] Posted March 11, 2020 Share Posted March 11, 2020 Please sign in to view this quote. Yes, the same in Virtual DMIS, if anyone remembers that software? Link to comment Share on other sites More sharing options...
[Ad...] Posted March 18, 2020 Share Posted March 18, 2020 Please sign in to view this quote. How would you do an offset without the proper alignment to that feature? Unless it's a two axis offset I would be concerned about the accuracy Link to comment Share on other sites More sharing options...
[Ri...] Posted March 18, 2020 Share Posted March 18, 2020 You would align to the feature first, then create the correct offset feature, and then align again. Link to comment Share on other sites More sharing options...
[SH...] Posted March 18, 2020 Share Posted March 18, 2020 Please sign in to view this quote. Yes ,i operated it, when I was working in Malaysia. I used an old version. Link to comment Share on other sites More sharing options...
