[Ni...] Posted March 16, 2020 Share Posted March 16, 2020 Hi, Is there a way to disable nominals from filling in automatically? Sometimes some of the characteristics automatically updates the nominal to what it thinks it is instead of what I already had. I have to search through them all the characteristics to make sure nothing else updated. Thank You Link to comment https://qualityforum.zeiss.com/topic/16230-disable-auto-nominals/ Share on other sites More sharing options...
[Ow...] Posted March 16, 2020 Share Posted March 16, 2020 Not sure this is what you're seeing but, Go to Resources and scroll down to select the Characteristics Settings Editor, then select Nominal Mode and choose "input in Characteristic" . If set to "Automatically from Nominal geometry", it will change every time the feature nominal changes. Link to comment https://qualityforum.zeiss.com/topic/16230-disable-auto-nominals/#findComment-90066 Share on other sites More sharing options...
[Ni...] Posted March 18, 2020 Author Share Posted March 18, 2020 Please sign in to view this quote. Thank You, that seems to have worked. Link to comment https://qualityforum.zeiss.com/topic/16230-disable-auto-nominals/#findComment-90068 Share on other sites More sharing options...
