Disable auto nominals
Hi,
Is there a way to disable nominals from filling in automatically? Sometimes some of the characteristics automatically updates the nominal to what it thinks it is instead of what I already had. I have to search through them all the characteristics to make sure nothing else updated.
Thank You
Not sure this is what you're seeing but, Go to Resources and scroll down to select the Characteristics Settings Editor, then select Nominal Mode and choose "input in Characteristic" . If set to "Automatically from Nominal geometry", it will change every time the feature nominal changes.
