Automatic measurements
guessing you either did not select them at CNC run ( which I normally see a similar but not the same message); or perhaps they are set to MAN (manual) under "Measurement Plan Editor features" Man / CNC mode.
Actually I use tip no 5 instead tip no.3 , that is why I got this message. I made same mistake in the program also.l have been operating calypso for two years, still l make this mistake often. I checked the CNC start window, it was using points to points instead use clearance plane. Sometime calypso programming feel like fairy tale stories 😮
