Easy Q, XXT
Can you change the Force of probing from low to med to high for a particular feature?
Or, say i have a tip angle of A0B0 #1 with a standard force, can i create another A0B0 tip #2 with high force?
If you qualify your tips using qualify passive stylus mode with the XXT you are able to measure three different probing behaviors of sensitive, standard, and robust. These options can be changed per feature in a program located in the measurement plan editor / probing / probing behavior of of passive sensors. The option that prompts you before qualification for the probing behavior "sensitive, standard, or robust" serves only as a default behavior when using that particular stylus or angle if its RDS.
