Older Versions of Calypso
Sorry for being a Newb!
I just started with a new company and they have 10 CMMs. All of these CMMs are running and older version of Calypso (2013)..
My question is.. can this same version be purchased to go on a new computer? If you purchase a new license can it be for 2013 version? The reason I'm asking this is because I will be programming offline and If I'm running a newer version, I don't believe an older version would run the program at each machine?? Correct?
Thanks In Advance,
Stan
Licenses are backwards compatible so if you buy a 6.8 license it will work for previous versions as well. However, between 5.4 and 5.6 there was a new licensing tool introduced so new licenses will not work with pre 5.6 versions.
You also have to consider the version of Windows you're running. I've been told that 5.6 and lower isn't compatible with Windows 10.
