how to make symmetry plane and point
hi sir, my name kamarulzaman, I want to know. how to make some symmetry plane and point. because I confuse to do this point. never get this point
To make a symmetry plane, create 2 planes, then select Construction>Symmetry and simply insert the 2 planes and calypso will create the midpoint.
Symmetry point is the same thing, you can use points lines or planes or just about any feature to create symmetry.
Or, if you click on "define Points" in the lower left corner and click a point, then click on a 2nd point on a different surface it will generate a symmetry point automatically.
After you close the newly created symmetry point it is set, then you can reopen it and adjust XYZ location of the points if you want.
