Increase object size of comment section
Guys,
I know this is probably a null question but I want to ask it anyway. Does anyone know a way to increase the size of the comment object on the start menu?
Good question with no known answer on my part but, autorun has a nice big comments section if you wanted to run everything out of it.
Something you're probably aware of but, back in another place where I had PCM, I used BAT files to open easy to read instructions when the program opened.
I'm going to use this for a change log. I currently use a .txt file tucked away in the 'user information' section but I wanted something that was inside of calypso. I used to use PCM to launch it when you opened the program but this was deemed 'really annoying' by my operators.
I really wish you could see the actual script and add comments to it like you can in PCDMIS; However, I've been told by people smarter than me that Calypso doesn't work like that.
We create separate documents for this and use the user information to link the document to the program. We then lock the document so it can't be changed and unlock it when we need to. Works great and keeps everything in organized in one location.
i could understand the annoyance of it popping up. The comment section will scroll so you can read through everything, it's just annoying.
Nope. Looking at my image I see how you could think that. I want the comment section larger to display more text at one time.
Edit: I fixed the image now
Ok, i have no idea about that.
BUT if you want to change the icon image in the corner to something else, maybe a screen shot of the cad model or anything but the stock image of a cmm that may or may not look nothing like the cmm you have, drop a bitmap image in your program folder named "icon.bmp" and calypso will automatically sense the picture and use it in the start window.
Note to self, make sure to remove picture of Chad from my program before sending program to network drive........
fgdjhfgjhfgdjhfgd.JPGFetching info... fgdjhkfgdjhfgdjhkfgdjhk.JPGFetching info...
Yeah,
and you should totally keep my picture on there. I could be the new face of medical implants.
I've always meant to change that to the company logo but haven't yet.
If you ever think you're about to get the boot by the corporate stooges, you can drop a little herpe like this into about 100 random programs in about 5 minutes.
Thats illegal, and should not be encourage under any circumstanses!
I just wanted to clarify the "correct" answer to the original question. Yes, it is possible. 🙂
The fact is that you can do pretty much anything.. Again, you are not allowed to do it. But it can be done.
