[Ke...] Posted March 5, 2020 Share Posted March 5, 2020 Checking to see anyone knows how or if you can even delete previous Base Alignments that you are not using anymore? Once you create one, you are not able to create another alignment under that same name. Link to comment https://qualityforum.zeiss.com/topic/16348-erase-base-alignments/ Share on other sites More sharing options...
[Ch...] Posted March 5, 2020 Share Posted March 5, 2020 Yes, They should be under : C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\basesystems by default. Link to comment https://qualityforum.zeiss.com/topic/16348-erase-base-alignments/#findComment-90768 Share on other sites More sharing options...
[Da...] Posted March 6, 2020 Share Posted March 6, 2020 why can't you create another alignment under the same name? You can have as many programs using the same Base Alignments as you want. We do this all the time but remember that it is over write by that last time it was ran. e.i. ( the X Y Z A1 A2 based on home position.) Link to comment https://qualityforum.zeiss.com/topic/16348-erase-base-alignments/#findComment-90770 Share on other sites More sharing options...
[Is...] Posted March 6, 2020 Share Posted March 6, 2020 Please sign in to view this quote. This is similar than the defined way of work in my company, I have only 2 base alignments for all programs: one is in the pallet and the second one in the RT. Link to comment https://qualityforum.zeiss.com/topic/16348-erase-base-alignments/#findComment-90772 Share on other sites More sharing options...
[No...] Posted March 6, 2020 Share Posted March 6, 2020 Please sign in to view this quote. Calypso offers a more convenient way: The file menu has an item for the erasure of base alignments. Link to comment https://qualityforum.zeiss.com/topic/16348-erase-base-alignments/#findComment-90774 Share on other sites More sharing options...
