Erase Base Alignments
Checking to see anyone knows how or if you can even delete previous Base Alignments that you are not using anymore? Once you create one, you are not able to create another alignment under that same name.
why can't you create another alignment under the same name? You can have as many programs using the same Base Alignments as you want. We do this all the time but remember that it is over write by that last time it was ran. e.i. ( the X Y Z A1 A2 based on home position.)
This is similar than the defined way of work in my company, I have only 2 base alignments for all programs: one is in the pallet and the second one in the RT.
Calypso offers a more convenient way: The file menu has an item for the erasure of base alignments.
