Planner Seat(Offline Programming) Location
Hello,
I was just made aware that there is something called a planner seat? That will let me do offline programming on another computer while operators use the CMM for inspections. I don't know how to access that or use it and would like some help on getting that working. I already installed calypso on my work laptop but I cannot run it because I don't have an activation key. The dongle is already being used by the CMM.
Where can I find the activation key for the planner seat or how do I get this set up so I can use it. Or is this something extra that needs to be bought?
What Amel said. FYI - The cost of planner and associated offline software packages (curve/PCM/gear) are roughly half of the CMM linked software.
Thank you but our company is not interested in getting another activatoin key. I was hoping it would already be bundled in.
Bummer but thank you for the information.
You would need to check your purchase paper work but it is offered free when you purchase a new machine on most sells quarters.
It could have been included with your purchase.
