PiWeb to AS9012
What is involved in getting Calypso to output results to an Excel spreadsheet form, i.e. AS9102? Have potential new Zeiss customer looking for new CMM and this is high on their "must haves" list.
Either you make a Piweb report that looks like the report. Or if it has to be populated to Excel, the most simple solution is exporting data with pcm and make a macro or a script that fills the Excel sheet. I have done reports like this (pcm/scripts) that fills in special reports in Excel for our r&d.
But Im no Piweb expert, so there might be a third option. However, I doubt that.
Hey Tom,
I would contact ZEISS in the US. I know (and have seen) PiWeb report templates for AS9012. They should be able to E-Mail the reports and you can modify them as you please.
Best Regrads,
Josh Smokovitz
Hey Josh. Long time no see. Yes, I got a AS9102 template from Greg E. Turned out customer didn't actually need output to their excel report and was okay with separate report from CMM. Customer loved output. Customer now looking at Mitutoyo and will make decision. They like Zeiss but also like cheaper machines. Hopefully our demo impressed them enough to go the Zeiss way.
  • 3 months later...
I know this is an older post that I'm dragging up but we are having the same issue. We previously had Calypso 2015 and PiWeb Flexreporter and it worked like a charm. Now we've upgraded to Calypso 2019 and have just the Piweb reporter. I'm needing an AS9100 form to use for my results printout. Is this something that Zeiss can provide for us or do we have to build our own? I figured there would be a default AS9100 style template somewhere to import then we edit it to our needs. Thanks in advance.
  • 3 weeks later...
