Tip chamfer Ø
Not that I am aware of. They could really improve their software by adding these minor features.
It can be done in Calypso, if you're familiar with aligning the gear tooth.
I would just measure small 3 lines (single points should be fine) and intersect them, then use simple distance.
Good luck.
