Importing OBJ Data
An .obj file can be imported by "File > Import" or drag & drop on the application.
Any accompanying .mtl file and color map (image) files should just exist in the respective path, not be selected or dropped as well.
  • 2 years later...
Once the .obj is imported, what is the best way to rotate it so that it matches the geometry of the measured object in GOM?
