[Ti...] Posted April 12, 2021 Share Posted April 12, 2021 is there any way to import .obj from a scanner, inlcuding color map data? Link to comment Share on other sites More sharing options...
[St...] Posted April 14, 2021 Share Posted April 14, 2021 An .obj file can be imported by "File > Import" or drag & drop on the application. Any accompanying .mtl file and color map (image) files should just exist in the respective path, not be selected or dropped as well. Link to comment Share on other sites More sharing options...
[Jo...] Posted May 9, 2023 Share Posted May 9, 2023 Once the .obj is imported, what is the best way to rotate it so that it matches the geometry of the measured object in GOM? Link to comment Share on other sites More sharing options...
