Installation of PyQT5 fails (also: how to use pip instead of package installer)
I wanted to create a custom gui for a customer and thus needed PyQT5 as the GOM GUI you can build has several limitations.
Problem: The installation of PyQT5 failed. Is this package not supported?
I also had problems when i wanted to install a specific opencv-version.  I mean GOM Suite is based on Python 3.9 , so is there any way to use the normal pip install syntax when using GOM?
Thank you very much in advance 🙂
  • 1 month later...
Thread can be closed, i found a way around the limitations.
For everybody interested: Open a command window
In this command window navigate to the directory of your gom python file (cd C:\Program Files\GOM\2022\python)  in my case.
Then use the python -m pip install mandelbrot syntax. Here mandelbrot is the package name
  • 1 year later...
