Measuring the Diameter of a Hex
So I have a hexagon and Im trying to figure out the DIA of it or even the distance from one side to the other. However something isn't working and Im lost. Help!!
Is it a hex driver? (major/minor diameters) We specialize in hexalobe surgical drivers. If you have curve, just slice a nominal plane through the section where you want to measure the diameter, section and Scan the curve. Then recall the curve points into a circle feature, and set the evaluation to MCE for the major dia, or MIE for the minor dia. Without curve, create a nominal circle, open a circle path, under "strategy" tick "single (6) points" then set your start angle and angle range to 360.
If it's simply a hexalobe shape (no major/minor dia), measure the 6 planes, and intersect them all (result 6 lines) intersect each intersection (line) to a plane on either the top or bottom (result 6 points) recall those points into a circle.
If its a small hex like Clarke stated for a hex drive, possibly you could just scan it as a circle and turn your filters on to maximum inscribed element, and it'll find the 3 points to make the smallest circle possible.
also you could create a "minimum feature" for this.
I've never done this for size, but i did do this (circle inside hex) for a true position callout that worked very well.
it matched up almost identical to hard gaging.
I recently had a drawing with hex that stated " .750" 3 places". I measured each with gage blocks. That accounts for draft and parallelism , but not for simultaneous flats. Ideally you would have a hex shaped go/no go which would meet functional requirement. If you gage with round pin, or max inscribed, it will be the smallest point but has no consideration of form.
