Measuring the Diameter of a Hex
Is it a hex driver? (major/minor diameters) We specialize in hexalobe surgical drivers. If you have curve, just slice a nominal plane through the section where you want to measure the diameter, section and Scan the curve. Then recall the curve points into a circle feature, and set the evaluation to MCE for the major dia, or MIE for the minor dia. Without curve, create a nominal circle, open a circle path, under "strategy" tick "single (6) points" then set your start angle and angle range to 360.
If it's simply a hexalobe shape (no major/minor dia), measure the 6 planes, and intersect them all (result 6 lines) intersect each intersection (line) to a plane on either the top or bottom (result 6 points) recall those points into a circle.
If its a small hex like Clarke stated for a hex drive, possibly you could just scan it as a circle and turn your filters on to maximum inscribed element, and it'll find the 3 points to make the smallest circle possible.
also you could create a "minimum feature" for this.
I've never done this for size, but i did do this (circle inside hex) for a true position callout that worked very well.
it matched up almost identical to hard gaging.
I recently had a drawing with hex that stated " .750" 3 places". I measured each with gage blocks. That accounts for draft and parallelism , but not for simultaneous flats. Ideally you would have a hex shaped go/no go which would meet functional requirement. If you gage with round pin, or max inscribed, it will be the smallest point but has no consideration of form.
