[FR...] Posted February 13, 2020 Share Posted February 13, 2020 Hey Guys, Does anyone have this similar construction issue? I have my 3D curve scanned and the min/max are around 0.001" there. Then I construct a new free form by using this 3D curve There has a very large discrepancy between the constructed free form and original 3D curve. Constructed form has 0.0404" and curve has 0.0007" on the min value. It did not make difference when Re-calculated box checked. There must be something about free form construction rules I don't know, like using 3D curve to construct, using plane feature to construct.... anyone could give me suggestion please? All my measurement and construction based on Base alignment.1.jpg Link to comment https://qualityforum.zeiss.com/topic/16508-free-form-construction-why-perfect-3d-curve-turned-to-bad-form/ Share on other sites More sharing options...
[FR...] Posted February 13, 2020 Author Share Posted February 13, 2020 Sorry please ignore the last view. Link to comment https://qualityforum.zeiss.com/topic/16508-free-form-construction-why-perfect-3d-curve-turned-to-bad-form/#findComment-91960 Share on other sites More sharing options...
[FR...] Posted February 13, 2020 Author Share Posted February 13, 2020 And it is not always turned to be bad, something it get even better..like this one my original 3D curve After recall feature points, it turned more better. Why? What is the concept behind it? Link to comment https://qualityforum.zeiss.com/topic/16508-free-form-construction-why-perfect-3d-curve-turned-to-bad-form/#findComment-91962 Share on other sites More sharing options...
[Ri...] Posted February 14, 2020 Share Posted February 14, 2020 You also need to associate the Free-Form with the surfaces. You do this by being inside of the Free-Form main window, and select the CAD surfaces that it is applied to. Link to comment https://qualityforum.zeiss.com/topic/16508-free-form-construction-why-perfect-3d-curve-turned-to-bad-form/#findComment-91964 Share on other sites More sharing options...
[FR...] Posted February 14, 2020 Author Share Posted February 14, 2020 Sorry Richard I can not get you. How can I construct the free form by selecting CAD surface? could you give more detail please? Link to comment https://qualityforum.zeiss.com/topic/16508-free-form-construction-why-perfect-3d-curve-turned-to-bad-form/#findComment-91966 Share on other sites More sharing options...
[Me...] Posted February 14, 2020 Share Posted February 14, 2020 Do you see the button that says "Surfaces Used" in the Free Form dialogue box? Link to comment https://qualityforum.zeiss.com/topic/16508-free-form-construction-why-perfect-3d-curve-turned-to-bad-form/#findComment-91968 Share on other sites More sharing options...
[FR...] Posted February 14, 2020 Author Share Posted February 14, 2020 Yes I saw it. Shall I choose it first? What I did is in the free form window, 1st choose recall feature points, then select the 3D curve, and then ok. Got free form with 0.040" deviation there. 3D curve itself has 0.0019" deviation. When should I check " surface used " selection? what is the step? 🫣 Link to comment https://qualityforum.zeiss.com/topic/16508-free-form-construction-why-perfect-3d-curve-turned-to-bad-form/#findComment-91970 Share on other sites More sharing options...
[FR...] Posted February 18, 2020 Author Share Posted February 18, 2020 And I did another try, this time instead of checking "surface used" button at the end, I hit it first and then choose recall feature points, then in the pop out window choose target 3D curve and ok. Still got same huge deviation. Is there anything I missed during the construction? Link to comment https://qualityforum.zeiss.com/topic/16508-free-form-construction-why-perfect-3d-curve-turned-to-bad-form/#findComment-91972 Share on other sites More sharing options...
