Duramax and Stylus System Creator (Star Probe)
When I create a Stylus System for a Duramax with Stylus System creator every time it comes it is rotated by 90 degrees? I am guessing that any one with a direct machine or a spectrum with only the XXT head has this same problem. How do I get the tip to import correctly? I start with none, then add the XXT, Star Probe Adapter, then the Styli in X and Y, but when I import it into to my offline seat it is always rotated incorrectly and if my styli are not the same length it is a pain to fix them. I can, but I am hoping I am just missing something.
The XXT on the DuraMax (I'm fairly certain it's only the DuraMax) is rotated 90°.
You can rotate the stylus system in Stylus System Creator. Select the XXT Plate, and change the Main Axis Angle to 90° (it might be -90° though).
