[Ke...] Posted March 14, 2019 Share Posted March 14, 2019 I am trying to find the XY location of a circle but I wanted to know if this can be done by taking a point in the diameter like we do to set the location of the probe rack. I have seen this done on Faro Arm's just wondering if it can be done in Calypso? Link to comment Share on other sites More sharing options...
[Me...] Posted March 14, 2019 Share Posted March 14, 2019 If you have the Calypso cookbook there is a procedure for dealing with a drill tip a the bottom of the hole. Also I sometimes have C'bores that are too shallow for my smallest probe, 1MM. I'll keep the probe high enough to not scrap the bottom. Hit 4 points obviously not getting dia. but getting location. I'll do the same thing for holes too small for the probe to enter. I don't know if I've answered your Q but there are some smart cookies here so hope they can also chime in. Link to comment Share on other sites More sharing options...
[Me...] Posted March 14, 2019 Share Posted March 14, 2019 If you're talking about self centering on a diameter you can do this with a point feature. Go to the strategy/probing point for the settings. Obviously you need to use a probe diameter larger than the hole size. Link to comment Share on other sites More sharing options...
[Te...] Posted March 14, 2019 Share Posted March 14, 2019 Can you do self centering accurately with a XXT head? Link to comment Share on other sites More sharing options...
[Br...] Posted February 13, 2020 Share Posted February 13, 2020 Please sign in to view this quote. Can you give a more detailed step by step? Im currently trying this strategy and it isnt working. Link to comment Share on other sites More sharing options...
[Ri...] Posted February 14, 2020 Share Posted February 14, 2020 Please sign in to view this quote. I was told at advanced class that the passive XXT can't do self centering. You need active scanning. I guess it will still go through the motions but without the active feedback your just working with spring tension and your results will be hit or miss. Link to comment Share on other sites More sharing options...
[Jo...] Posted February 14, 2020 Share Posted February 14, 2020 short line scan across hole in X and Y to get lowest coordinates ? I use this method to get location of scribed indicator lines that are too small to probe. Link to comment Share on other sites More sharing options...
