ID Callout
Just got a print rev level change and they added the call out that is attached. Never dealt with one like this..
What I did in my prg was as follows:
GX 22.3 +.04/-0.0
LP 22.3 + .13/-0.0
Am I on the right track here or am I off base. But then again it is early here. Also ISO 🤣
Keith is correct. The tolerance for both evaluations is +0.13 +0.04. In Calypso to do a LP, you will use the 2-Point Diameter Characteristic, and then you will select the LP size. For the GX (Outer Tangential), use a normal Diameter measurement, and switch your evaluation over to Outer Tangential.
