[Mi...] Posted February 11, 2020 Share Posted February 11, 2020 Just got a print rev level change and they added the call out that is attached. Never dealt with one like this.. What I did in my prg was as follows: GX 22.3 +.04/-0.0 LP 22.3 + .13/-0.0 Am I on the right track here or am I off base. But then again it is early here. Also ISO 🤣 Link to comment Share on other sites More sharing options...
[Ke...] Posted February 11, 2020 Share Posted February 11, 2020 LP = Two Point Size GX = Max Inscribed So: 22.3 + 0.13/+0.04 https://help.solidworks.com/2019/Englis ... t=P&value= Link to comment Share on other sites More sharing options...
[Ri...] Posted February 11, 2020 Share Posted February 11, 2020 Keith is correct. The tolerance for both evaluations is +0.13 +0.04. In Calypso to do a LP, you will use the 2-Point Diameter Characteristic, and then you will select the LP size. For the GX (Outer Tangential), use a normal Diameter measurement, and switch your evaluation over to Outer Tangential. Link to comment Share on other sites More sharing options...
[An...] Posted February 12, 2020 Share Posted February 12, 2020 The combination of GX;GN and LP does not make sense in my opinion. See attached.Contribution_12_02_2020_1.pdf Link to comment Share on other sites More sharing options...
