PCM nominals/alignments
We have a family of parts program. The program would not run. Looking at the nominals, they were all 99999. So, I highlighted everything in the presetting's and hit compute. This re-loaded the correct nominals, but the program would still not run. After I left my other programmer ended up reloading all the features in every secondary alignment and the program ran. We are just trying to understand why that would fix it?
Did you get this figured out?
My thought , without knowing all the details is that something in your presettings isnt getting defined until later, so it wont populate when the program runs but after the program runs you can highlight and compute.
If so, you may need to move some of your variables further down, maybe in the presettings of the feature in question.
Yes, we got it working. This program was written for us by Zeiss. The model (.sab) is located in the .para file.
When I execute it, I'm prompted with a message that states; (somethin like) "a parameter is not recognized,
and will be skipped". Again, this isn't the exact wording, but I'm sure it's eluding to that .sab file. I'm not sure
why the CAD model would need to be in the para file?
