[De...] Posted February 7, 2020 Share Posted February 7, 2020 CALYPSO v6.6.20 (11.07.2019) Очень долго выполняется формирование данных после замеров. Но не всегда, при первом старте (перезапуск CALYPSO) достаточно быстро. ================================================================= It takes a very long time to generate data after measurements. But not always, at the first start (restart CALYPSO) fast enough. p.s. in the video attachment to understand how slow data collection is VID_20200207_141251.7zFetching info... Link to comment Share on other sites More sharing options...
[SH...] Posted February 7, 2020 Share Posted February 7, 2020 Please sign in to view this quote. Link to comment Share on other sites More sharing options...
[De...] Posted February 7, 2020 Author Share Posted February 7, 2020 It takes a very long time to generate data after measurements. But not always, at the first start (restart CALYPSO) fast enough. Link to comment Share on other sites More sharing options...
[Is...] Posted February 7, 2020 Share Posted February 7, 2020 Возможно, рабочая станция не соответствует минимальным требованиям (например, ОЗУ) 😎 (Thanks Google translate) Link to comment Share on other sites More sharing options...
[Is...] Posted February 7, 2020 Share Posted February 7, 2020 Maybe the Workstation does not accomplish the minimum requirements (RAM for example) 😎 Link to comment Share on other sites More sharing options...
[De...] Posted February 7, 2020 Author Share Posted February 7, 2020 I doubt see the attachment 1.jpgFetching info... Link to comment Share on other sites More sharing options...
[Ro...] Posted February 7, 2020 Share Posted February 7, 2020 У меня есть программа с большим количеством профилей, это может занять несколько минут для расчета. Хуже, если ваши данные сделаны из построенных элементов. Компьютер, поставляемый с вашим Zeiss, хорош, но недостаточно мощен для сложных вычислений. Вы должны посмотреть на очень большое обновление оперативной памяти, однако ваш компьютер может держать. I have program with lots of profiles, it can take several minutes to calculate. It's worse if your datums are made of constructed features. The computer that came with your Zeiss is good, but not powerful enough for advanced calculations. You should look into a very large RAM upgrade, however much your computer can hold. Link to comment Share on other sites More sharing options...
[De...] Posted February 7, 2020 Author Share Posted February 7, 2020 No, it seems to me that this is connected with this version of CALYPSO, because we most recently worked in CALYPSO version 4.6 with the same program and did not notice such problems. Link to comment Share on other sites More sharing options...
[Ch...] Posted February 7, 2020 Share Posted February 7, 2020 I think you are all correct. I saw similar issues upgrading to 6.4 last year. We had lots of RAM 64GB, and it would hang at the end of a program with all standard features/geometries. We have since upgraded to about 128GB RAM, and the lag/wait times are gone. Good luck! Link to comment Share on other sites More sharing options...
[Is...] Posted February 10, 2020 Share Posted February 10, 2020 Strange,normally 64GB should be enough.. mabe the windows version or the company policies are releated. Link to comment Share on other sites More sharing options...
