Results printing date
Hello guys
I have question regarding results print out.
In program I turned on measuring points save. So we can get old results also( I mean two or more day back results in program). But my question is I wan last two days back report with same date( two days back). Whenever I opened two days back report came up with present date and time. But I want same date and time. Because I lost my backup PDF format reports. Can anyone help me.
I don't know how to explain this, but I hope you guys are understanding.
Thanks in advance.
if Keith's idea doesn't work and you absolutely have to have the old date on the report then I see two options.
1.Change the data using a PDF editor.
2. Go in the report design and change the date variable to a string with the desired date. (probably more work than it is worth for just one report.)
You can easily do it in pi web, it's a piece of cake. Daily I am doing that, because my company people asking always early days report to fabricate auditing documents. After you run the entire program the piweb report would pop out, then press f6, l I have attached that photo. It was given by one of this community member to me, not mine. In my knowledge piweb automatically save last ten reports.
