Part size on xlsx report
I have a family of parts program utilizing PCM to change nominals and models. I figured out how to insert a formula into the compact printout comment field to identify which part has been run. I need to do the same thing on the excel report, but do not know how. Below are my current postsettings;
//Dims to Excel
filePath = "T:\DMR\CMM Data\Medtronic\Part Flat Profile_.0934 (feature 200)\"
ext = ".csv"
//N1 = getRecordHead ("Grind Tang_Rev. B 9.22.16_543_.0934")
//dirPath = filePath + N1 + (" ") +date()+" "+time()+ ext
Lot = getRecordHead("order")
partnum=getRecordHead("partnbinc")
dirPath=filePath+Lot+("_")+partnum+ext
display(dirPath)
if fileExists(dirPath) == true
deleteFile(dirPath)
endif
//#1
DIM200_1 = getActual("200 - Profile_1").actual
//#2
DIM200_2 = getActual("200 - Profile_2").actual
addToFile(dirPath,date())
addToFile(dirPath,time())
addToFile(dirPath,("T:\DMR\CMM Data\Medtronic\Part Flat Profile_.0934 (feature 200)"))
addToFile(dirPath,("Lot Number : "),LN)
addToFile(dirPath,("200 - Profile_1 : "),DIM200_1)
addToFile(dirPath,("200 - Profile_2 : "),DIM200_2)
If you're already using if statements or operator inputs for your part numbers, could you just add another variable that will be the part number?
part_num = inquireList("Which part number would you like to run?", "8mm", "10mm", "12mm", "14mm", "16mm", "18mm")
if itemSelected=="8mm" then
readPCMFile(getActualInspectionDir()+"\8mm.para")
THISPART="8mm"
endif
if itemSelected=="10mm" then
readPCMFile(getActualInspectionDir()+"\10mm.para")
THISPART="10mm"
endif
Then maybe a line such as partnum=(getRecordHead("partnbinc"))+THISPART
Then addToFile(dirPath,partnum)
