Any of you guys have to clock the flutes of an end mill?
Im working remotely with sister plant, we don't have parts yet just a drawing & a model.
So its just a standard 4 flute end mill, i don't think there is anything special about the geometry, but they put a drive end on the back so Dr Robot can handle it.
There is a TP diameter callout from the apex of the 4 flutes back to the main shaft which seems easy enough, but since there is nothing 'Clocking' the flutes i don't know how to best locate it.
I've used Step points before on 1 family of parts, but i've found them to be very fussy, and i don't want to saddle them with that.
Any of you guys have a way to find rotation on the flutes? what was your best solution?
FYI, they have FF but no Curve.
I had something similar once. I physically clocked it, then used two
space points on either side of one flute and created a symmetry
point from them to use for clocking.
I measure supercharger rotors all day long I can tell you what I do.
I measure a 360 degree profile near the top of the part with curve. Then I best fit that curve to whatever alignment rotational around Z. Create an alignment from this curve.
Then I measure however many more 360 degree profiles I need. Align all other curves to best fit curve alignment.
I have a really good set of instructions for this strategy but I can't find it right now. I'll post if I find it.
