[Lo...] Posted January 25, 2020 Share Posted January 25, 2020 I need your help! I created a measurement plan of a steel plate in space axis +z . Now we have add other holes in the back side of the plate ( space axis -z). To measure them, i would like to put the item in vertical on CMM so i can take the bores in space axis +y on one side and -y on the back side. Can i do that without delete the measurament plan? This program took a long time. Tanks for your assistance. Link to comment Share on other sites More sharing options...
[No...] Posted January 27, 2020 Share Posted January 27, 2020 Regardless of whether I repeat myself for the 1000th time here on the forum (I guess I should make a tutorial, if I only had the time), the answer is: YES! 😃 Basically, Calypso can measure a part in every physical orientation as long as the base alignment is fully defined in all degrees of freedom. This is true for the software side. Restrictions apply to the hardware side (CMM type and styli): Of course you can only measure with styli which can properly reach the features. So what you have to do is to edit all the styli in the measurement plan according to the new part orientation. Additionally, you may have to edit some clearance planes. Remember, clearance planes refer to the base alignment, so your former +Y will still be +Y for Calypso, but will physically on the CMM become -Z. So if any features have clearance plane +Y, you'll probably have to edit them to something else and maybe even insert an approach path in the strategy. Apart from these minor changes, you can use the measurement plan you already have. The most important thing is that you manually measure your base alignment exactly in the same way as before, only tilted. So if you probed a plane in machine axis +Z for spatial before, you now probe it in machine axis +Y, as this is your base alignment +Z now. I hope you understand what I mean 🤠 (I SHOULD definitely make a tutorial...) Link to comment Share on other sites More sharing options...
[An...] Posted January 27, 2020 Share Posted January 27, 2020 Please sign in to view this quote. Versuch's doch mal mit Kopieren und Einfügen. Link to comment Share on other sites More sharing options...
[Da...] Posted January 27, 2020 Share Posted January 27, 2020 The time is always critical. Please sign in to view this quote. You should, we all should, well you should 😃 Really, joke aside. Some stuff repeats itself and I was thinking it would be nice to have something dedicated to a specific problem. Maybe something marked like this? In theory when tutorials stack up, Carl will open new forum section. edit: And like Andreas would like to point out, this thread should be in "parent" Calypso section. Because of english language used. Link to comment Share on other sites More sharing options...
[No...] Posted January 27, 2020 Share Posted January 27, 2020 Please sign in to view this quote. I really like the idea of a tutorials section. Some topics repeat over and over again, and the search function is not always helpful, especially when it ignores a lot of words. Please sign in to view this quote. Fully agreed. Maybe this section should be better named "Calypso GER". Some people seem to miss the meaning of "DE" 😕 Link to comment Share on other sites More sharing options...
[An...] Posted January 27, 2020 Share Posted January 27, 2020 Please sign in to view this quote. DELAWARE Abbreviation: DE Should be simple for the US folks. Link to comment Share on other sites More sharing options...
[Lo...] Posted January 27, 2020 Author Share Posted January 27, 2020 Thanks a lot, for your answers ....you have solved my day. 😃 A tutorial could be a good and right thing. Link to comment Share on other sites More sharing options...
[To...] Posted January 29, 2020 Share Posted January 29, 2020 Please sign in to view this quote. 🤣 🤣 🤣 Link to comment Share on other sites More sharing options...
[An...] Posted February 3, 2020 Share Posted February 3, 2020 Should be simple for the GER folks.Beitrag_02_02_2020_b.jpg Link to comment Share on other sites More sharing options...
[No...] Posted February 3, 2020 Share Posted February 3, 2020 To be fair, they apologized later 😃 Link to comment Share on other sites More sharing options...
[An...] Posted February 3, 2020 Share Posted February 3, 2020 Correction: DE in this case means: Deutschland Link to comment Share on other sites More sharing options...
[To...] Posted February 3, 2020 Share Posted February 3, 2020 Please sign in to view this quote. https://www.youtube.com/watch?v=dLECCmKnrys Link to comment Share on other sites More sharing options...
