Crooked Stylus System
I have the standard M5 stylus system kit. There are some technical issues with my network but I decided to prepare some different stylus systems. I have made a 5 point stylus system but I cannot seem to orient it straight on the adapter plate (X+ < X-, Y+>Y-). Am I assembling these incorrectly or is there an automatic correction made when qualifying the stylus system?
https://qualityforum.zeiss.com/topic/16678-crooked-stylus-system/
  • 4 months later...
When I use a stylus setup very similar to yours, I align one stylus, usually the X- axis side (habbit?), to .0010 (Inch) per inch in the X axis.
This is an attempt to have some level of accuracy even though the assembly parts are generally quite a bit out of Parallel and perpendicularity.
Zeiss really needs to make these components with a higher degree of accuracy for what they charge.
https://qualityforum.zeiss.com/topic/16678-crooked-stylus-system/#findComment-93188
