[Wa...] Posted January 23, 2020 Share Posted January 23, 2020 Good day, We are curious as to whether or not anyone has had issues renaming features and characteristics by the values. For example: if we had a 2.5" cylinder Calypso defaults it as "cylinder1". If we were to rename it as "2.5 Cylinder" (to include the symbols like the decimal place), has anyone had any issues? We are trying to avoid the confusion as to locating features and characteristics when the numbering can get quite high (example: cylinder53). Regards, Link to comment Share on other sites More sharing options...
[To...] Posted January 23, 2020 Share Posted January 23, 2020 Attached are 2 methods I use. One shows without balloon numbers and one with. It's easy to use copy and paste between features and characteristics. Link to comment Share on other sites More sharing options...
[Wa...] Posted January 23, 2020 Author Share Posted January 23, 2020 Ok thank you Tom so if you had a 30.5mm hole Feature name: Cylinder_30.5mm Dia_Front Characteristic Name: 30.5mm Dia_Front worried about the decimal point Link to comment Share on other sites More sharing options...
[Ro...] Posted January 23, 2020 Share Posted January 23, 2020 I use a number sign (I refuse to call it a hashtag) in my naming strategy without any issues. My sister plant uses underscores and dashes and decimals without any issues. I think you should be finehfghfghd.JPGjhkghfghfgd.JPG Link to comment Share on other sites More sharing options...
[Wa...] Posted January 23, 2020 Author Share Posted January 23, 2020 Thank You Roberto Link to comment Share on other sites More sharing options...
[To...] Posted January 23, 2020 Share Posted January 23, 2020 Please sign in to view this quote. Decimal point is ok as long as it does not end with one. Calypso will bark at you whenever you use an invalid character. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 29, 2020 Share Posted January 29, 2020 I have been using the following method (With minor revisions thru the years) for about 16 years now. IMO, it makes a clean and readable report particularity when all in the company whom create CMM programs follows the same language. (Its from a 12 page document of CMM standards I wrote many years back). Section 11: Standard nomenclature for GD&T string entry in Calypso Characteristics (ProLink) 1. Character string Length Notes a. 30 max character limit for those outlined. All others are 32 max character limit. b. When using Best Fit true position. Calypso adds three or more characters to the string name, you must take care to prevent exceeding a 28 character maximum character limit. From Calypso GD&T character Standards Roundness = Rnd_.001 Roundness Ang = RoA_.001 Flatness = Flat_.001 Straightness = Strt_.001 Cylindricity = Cyl_.001 Profile = Prof_.010_A_B_C Prof_.010M_A_B@M_C@M Prof_.010_A-B_C Line Profile = LProf_.010_A_B_C LProf_.010M_A_B@M_C@M LProf_.010_A-B_C Form = Form_.001 True Position = TP_Ø.010_A_B_C TP_Ø.010M_A_B@M_C@M TP_Ø.010M_A-B_C@M True Position = TP_Ø.010_A_B_C TP_Ø.010M_A_B@M_C@M TP_Ø.010M_A-B_C@M See image “Best Fit naming Issues for ProLink.jpg” below Concentricity = Con_.001_A Coaxiality = Coax_.001_A Perpendicularity = Per_Ø.001_A Per_.001_A Per_Ø.001M_A-B Parallelism = Par_.001_A GDT Symmetry = Sym_.001_A Sym_.001_A_B_C Angularity = Ang_.001 Runout = Radial = Ro_.001_A Cumulative Radial Runout = TRo_.001A Axial = ARo_.001_A ARo_.001_A_B Cumulative Axial Runout = TARo_.001_A TARo_.001_A_B See attached sample PiWeb report "Naming Sample_-_20_3_PiWeb.pdf". As for features, Generally Calypso names them except for Datums: Plane_A (A plane for Datum A) ...If multiple features create a datum: Plane_A1, Plane_A2, etc; Creates Plane_A Circle_B (A circle for Datum B) etc...etc... To know association of characteristics to features and vice versa, Calypso does a fine job of association. Right click (Mouse) a characteristic and select "References of selected features" and all associations will appear in a dialog box. Right click (Mouse) a feature and select "Check use of selected features" and all associations appear in a dialog box. As a side note, if anyone wants to take time to review my "workmanship standards" and perhaps provide feedback, let me know via this forums message board, I will gladly provide a MS Word document.Naming Sample_-_20_3_PiWeb.pdf Link to comment Share on other sites More sharing options...
