PiWeb
Please go to Designer
Select the Chart
Property-Y-axis - Measured Data range select Custom
Value range Change whatever you want.
I hope this will help you removed all the Negative
Hello, I noticed this after posting on the forum. After making this setting, all graphics are affected. So when I make this setting, I need to make special settings for each graphic. As I am using a common form, all the measures were obviously affected. This is not possible for me since I use too many programs and the programs are too long
