true position/max material
Not sure if this should be put in the Piweb reporting or here, but I have a part that has a true position call out for a hole location and has .005" Max material condition. When the report generates after the part run I get 2 lines of data with the true position. One with the true position and another with an (M) at the end. What am I looking at and why does it spit out 2 results for one feature?
The second result is the recalculated first result in relationship to the
"Nominal True Position" (without MM bonus).
It's important for cmk/cpk.
