Profile of Chamfer Help
I would either measure a cone with two circle paths, or maybe get a little fancy and
create two 2d curves in the cone and recall those points into a free form surface.
Do you have curve?
Both the cone and the FFS can then be pulled into the surface profile characteristic
for evaluation. With no datum reference they want only form.
I had issues with the profile of a plane and contacted one of the Application Engineers at Zeiss. He suggested that since the profile didn't have a datum reference to put the plane itself 3x for the datums. This worked for the plane very well but have not had any success with the profile of the chamfer.
I do not know when you purchased the license for your CMM, but when we upgraded our Planner with Curves-Free Form Surface it came as a package and I believe cost $6900.00 US.
Is it possible the license is not Activated? Check this under Extras>Settings>Miscellaneous>Licenses. Here is were you can check to see if it is activated. Note you must me logged in as Master to make changes. 333_aa3693fd38532b05d82e1cfaaa9bd7ed.jpg
Greg
