[He...] Posted May 1, 2018 Share Posted May 1, 2018 Hello, is there a way to switch a negative result on a report to a positive. Example, I have a length that comes from the X zero of my program. It reports out as -.875, is there a way to change it to a positive? I see that I can put a formula in the result, is that the best way to switch it to a positive? Thank you!! Link to comment https://qualityforum.zeiss.com/topic/16764-negative-to-positive-reporting/ Share on other sites More sharing options...
[To...] Posted May 1, 2018 Share Posted May 1, 2018 Are you using an X characteristic? You could solve your issue by using a distance of some sort, such as Cartesian Distance. The result will always be positive. Using the X, Y or Z checkbox in a feature is not always the best solution. For circles, maybe. But for planes, hardly ever. A former "ol' timer" from Zeiss, no not you Mr. Helle, once said to me, "What is an X characteristic? Where is it in the standard?" Thank you MB.... Link to comment https://qualityforum.zeiss.com/topic/16764-negative-to-positive-reporting/#findComment-93764 Share on other sites More sharing options...
[No...] Posted May 2, 2018 Share Posted May 2, 2018 Can you describe your intention more precisely? Do you want ALL negative results to be reported positive? Do you just need a positive actual displayed or also a correct evaluation? Displaying (not calculating!!) a negative value as positive on the PiWeb report is a piece of cake, but doing this only with selected values or even get a correct tolerance evaluation is much more difficult if not impossible. So it depends on what exactly you want to do. Link to comment https://qualityforum.zeiss.com/topic/16764-negative-to-positive-reporting/#findComment-93766 Share on other sites More sharing options...
[He...] Posted May 2, 2018 Author Share Posted May 2, 2018 Please sign in to view this quote. It is an X characteristic, this is the best solution to my problem. Thank you very much. Link to comment https://qualityforum.zeiss.com/topic/16764-negative-to-positive-reporting/#findComment-93768 Share on other sites More sharing options...
[He...] Posted May 2, 2018 Author Share Posted May 2, 2018 Please sign in to view this quote. I think I already have a solution, but to answer your question. We import our data into IQS, the engineers were questioning the negative result. Changing it from a characteristic to a length seems to be the easiest fix. Thank you for your response. Link to comment https://qualityforum.zeiss.com/topic/16764-negative-to-positive-reporting/#findComment-93770 Share on other sites More sharing options...
[Ro...] Posted January 15, 2020 Share Posted January 15, 2020 Please sign in to view this quote. Hello Herendeen Mark, It is possible to help me with a solution for importing data into IQS? We are struggling to type all values manualy because we could't find a way to use the options for importing datas from Calypso. Many thanks in advance, Mihai Rohan Link to comment https://qualityforum.zeiss.com/topic/16764-negative-to-positive-reporting/#findComment-93772 Share on other sites More sharing options...
[Se...] Posted January 20, 2020 Share Posted January 20, 2020 Hi, we use the comment field to set the Position number. Then you shall Import your .txt file in IQS (see Picture attached) Should save a lot of typing ! 😃IQS.png Link to comment https://qualityforum.zeiss.com/topic/16764-negative-to-positive-reporting/#findComment-93774 Share on other sites More sharing options...
