Calypso 101 question, VPHEAD.gra
Ok, so all of my programs use the same header, VPHEAD.gra in the default folder.
My personal header has 2 user inputs at the start for the operator to type in the work order and individual part number.
I just finished some sweet PCM stuffs for one of my programs that services 7 part families and 6 millimeter thicknesses (42 parts), and in doing so i've made this 1 program generate its own part number based on 2 inquireList entries.
So now that the part number generates itself, i don't want the operator to have to do it, because at some point the operator could make an err and we could have 2 conflicting parts numbers on the same printout.
i went into my Header editor and copied my VPHEAD and named it for the part family, but when i went into my "Define printout" i just realised that i cannot select a particular VPHEAD file, i can only select a folder, which is still "default"?
Then I tried copying the Default folder and giving it a name that reflects my part family and renaming the new "VPHEAD-Partnumber" to "VPHEAD", and told calypso to use the new folder.
Now the custom report has no part number showing but the operator is still being prompted to enter it.
I tried checking and unchecking the box for User input, i tried closing and reopening the program, noting makes the part number input go away.
What am i missing?
I don't use incremental.
the 2 userfields i have are "Order" and "Part Number"
The userfield i deleted but wont go away is "Part Number"
1. i didn't have to edit anything but the VPHEAD for them to appear, i just had to add them to the header and click on the 'Force input at start' box.
2. would this affect any other programs?
3. how do you do it?
My mistake. I forgot there was a part number header and mixed the two up. You should still be able to use the multiple printout header window though? I was able to add and then remove the part number input with it as a test. Then again, I haven't tried changing around the custom printout header, but if removing the field there isn't dropping it from the operator input window, it's all I can think to do.
Did you delete the Part Number field from the vphead.gra in the default folder?
I just did that with one of the fields and it removed it from the user input.
