[Ne...] Posted January 8, 2020 Share Posted January 8, 2020 My problem is, until the machine measuring the part, its a long time, but i need a partial results, the dimensions measured so far because the CNC operator needs it that he can adjust the CNC machine. How can I set this? Its possible? Link to comment https://qualityforum.zeiss.com/topic/16868-show-partial-results-during-measuring/ Share on other sites More sharing options...
[Ma...] Posted January 9, 2020 Share Posted January 9, 2020 You can create a mini-plan to run only the characteristics that you need. Link to comment https://qualityforum.zeiss.com/topic/16868-show-partial-results-during-measuring/#findComment-94386 Share on other sites More sharing options...
[SH...] Posted January 10, 2020 Share Posted January 10, 2020 Please sign in to view this quote. You can create either a sub programme or select the features , you would like to run and select current selection from start measurement window.Be carefull with clearance plane, if you use X+, and-X in a row possibility of collusion is there......IMG_20200110_182114.jpg Link to comment https://qualityforum.zeiss.com/topic/16868-show-partial-results-during-measuring/#findComment-94388 Share on other sites More sharing options...
[To...] Posted January 10, 2020 Share Posted January 10, 2020 After you've measured the critical feature, go to the View menu and select Default Printout, it will show the results of the features measured up to that point. This may or may not be adequate depending on evaluation settings. If you run your programs from the "characteristics list", then the Default Printout will report your characteristic results, with their intended evaluation settings. Hope this helps. Link to comment https://qualityforum.zeiss.com/topic/16868-show-partial-results-during-measuring/#findComment-94390 Share on other sites More sharing options...
[Jo...] Posted January 10, 2020 Share Posted January 10, 2020 Mini plans are great for different operations. I will write an entire program and assign min plan to each operation. It will include additional information to facilitate machining adjustments. I will report form to identify potential problems at each operation. I may also apply tighter than print tolerances for certain features to prevent tolerance stack up in subsequent operations. Comments made in the characteristics also help clarify results to machine operator. I typically report LSQ. MAX INSC. and cylindricity on holes and bores, as well as qualify flatness on Datums etc..If there is a form error from fixturing, CAD evaluation is the fastest way to communicate that. Link to comment https://qualityforum.zeiss.com/topic/16868-show-partial-results-during-measuring/#findComment-94392 Share on other sites More sharing options...
