Result Element and PiWeb Report Mismatch
When reporting out the translation and euler angles of a coordinate system, I notice that the value for euler4 is not the same when comparing the results in the characteristic window with the results in the piweb report. Everything other than euler4 is correct. Has anyone come across this before? Is this a bug in the software (ver 6.8.0404)?
The result element window contains the correct euler4 value. The erroneous value is in the PiWeb report and I'm not sure why these two values would be different since the report should be pulling values from the characteristics list.
