How to Manually Release Stylus System- RDS Vast XXT
When I click on "Release stylus system" it gives me a 5 second rundown. After 5 Seconds I hear a click. No matter how hard I pull after that click, the stylus will not release. Calypso still recognizes the active stylus. Can someone please tell me how I'm being dumb?
Just read a note in the manual "The RDS adapter plate is locked. To remove it, press the push-button on the adapter plate."
I don't see a push button?
Try and release using the controller. You will need someone to grab the probe once you do the button sequence for releasing, as it doesnt countdown at all when those 3 buttons are used.
F2,SHIFT,BOTTOM RETURN BUTTON
Clark, are you talking about the button close to "A" in the pic below? I tried pressing that in and it didn't do anything. 2516_c01c024a0e6d31645a39694cf002c5d5.png
Shane, in that order and hold them down? It seems to just bring up a menu when I do that combination.
Sorry, I'm definitely using the wrong phrasing here. I don't want to remove the entire XXT Probe, I just want to remove the stylus system. My bad, I'll update the title.
You were right. I just had to gather my balls and pull, came right off. Thanks for the help.
The reason I did this is because we moved our stylus system holder, and I couldn't grab the master probe. I have now defined the holder (within the "cnc stylus system change) for where the master probe should go. It goes exactly where it should, but it doesn't release the stylus inside the holder. It just raises up in the Z with the stylus still attached. Ever experience this?
Today is not my day.
Edit: Determined that it's positioned too high in the Z to drop off. So I must be determining my stylus length incorrectly.
  • 6 years later...
Will you not damage the RDS if you just pull it, I am in the same boat. I am not getting that click release sound and I am hesitant to just pull it off.
If you are talking about removing the probe from the XXT, do not select " release probe. Just firmly grab the shaft of the probe and tip/pull it towards you at an angle. That will release the magnet. Pulling straight down does feel like it would damage something inside of the XXT.
Edited
  • Like! 1
No I am meaning to remove the XXT from the RDS but it wouldn't come off, you know you release the probe and on the XXT it releases the XXT sensor itself and you have to press the little black tab it and it just comes right off. Mine is stuck.
Chances are the locking mechanism, which is plastic, became deformed, most likely by attaching the sensor without using the little black button on the side.
I have repaired many of these by hand, but at some time you will need a replacement part, and I am not sure if Zeiss sells just the locking mechanism.
